This week in Armbian development saw significant progress across board support and kernel updates. New boards such as the Cainiao CNIOT Core, EByte ECB41-PGE, DG SVR 865 Tiny, and NORCO EMB-3531 received initial support, expanding hardware compatibility. Kernel patches were rewritten for the meson64 and rockchip64 platforms, aligning with version 6.18.18, while edge releases were bumped to 7.0-rc3 and rc4. Improvements included enhanced SD card and audio support for SpacemiT and Youyeetoo YY3588 boards, as well as refined configuration checks and display fixes. Several upstream patches were dropped or disabled, and the Dependabot schedule was updated for daily maintenance. Additional fixes addressed USB modes, Docker host-gateway resolution, and Xorg display issues, rounding out a productive week for the Armbian project.
- Add cainiao-cniot-core board and cainiao vendor image. by @retro98boy in armbian/armbian.github.io#251
- Add EByte Vendor // ECB41-PGE board. by @vidplace7 in armbian/armbian.github.io#250
- add recomputer rk3576-devkit dts. by @ackPeng in armbian/linux-rockchip#451
- Add support for the Radxa Display 10 FHD to the Rock 5B Plus. by @FlorianKohn in armbian/linux-rockchip#453
- add: initial support for DG SVR 865 Tiny board (SM8250/QCS8250). by @Lemon1151 in armbian/build#9423
- arch: arm: dts: add EByte ECB41-PGE (RK3506g2). by @vidplace7 in armbian/linux-rockchip#454
- armbian-zram-config: refine check for existing /tmp mount. by @vidplace7 in armbian/build#9514
- cainiao cniot core improve. by @retro98boy in armbian/build#9526
- chore: update Dependabot schedule to daily updates. by @igorpecovnik in armbian/build#9537
- csc board: Add NORCO EMB-3531 initial support. by @retro98boy in armbian/build#9456
- Drop patches that landed upstream and fix two. by @igorpecovnik in armbian/build#9544
- edge: bump 7.0 to rc4. by @EvilOlaf in armbian/build#9543
- extension: ccache-remote: fix Docker host-gateway for hostnames resolving to loopback. by @iav in armbian/build#9505
- fix(orangepi5max): change usbdrd_dwc3_0 mode from otg to host. by @Echoflare in armbian/linux-rockchip#449
- fix: correct repository dispatch event type name. by @igorpecovnik in armbian/armbian.github.io#254
- framework run_host_x86_binary_logged - support 32-bit x86. by @tabrisnet in armbian/build#9466
- Gateway AM-GZ80x: Update $board and meson-axg family conf. by @pyavitz in armbian/build#9533
- maint: meson64-current: rewrite patches against 6.18.18. by @EvilOlaf in armbian/build#9528
- maint: rockchip64-current: rewrite kernel patches against 6.18.18. by @EvilOlaf in armbian/build#9527
- meson64: a311d: Fix Xorg display when etnaviv enabled. by @retro98boy in armbian/build#9524
- Odroid-M2: Support for weather board zero. by @mlegenovic in armbian/build#9523
- odroidn2: u-boot: bump to v2026.04-rc3; make fancy, incl LWIP. by @rpardini in armbian/build#9507
- OrangePi 3 LTS: Update $board.conf file. by @pyavitz in armbian/build#9495
- OrangePi-RV2/R2S: add sdcard and emmc for Linux-7.x. by @sven-ola in armbian/build#9539
- Reword BTF memory check. by @x13-me in armbian/build#9502
- RK3506: Add spidev overlays for RK3506 family. by @vidplace7 in armbian/linux-rockchip#450
- rockchip64: bump
edgeto 7.0-rc3. by @EvilOlaf in armbian/build#9445 - rockchip64: cleanup old patchsets. by @EvilOlaf in armbian/build#9498
- rockchip: Add CSC board EByte ECB41-PGE (RK3506G). by @vidplace7 in armbian/build#9513
- rockchip: refresh LibreELEC patch import for edge 6.19 kernel. by @paolosabatino in armbian/build#9506
- rockchip: restore proper LE patches for rockchip armhf. by @paolosabatino in armbian/build#9530
- rpi4b: bump edge to 7.0. by @EvilOlaf in armbian/build#9529
- Spacemit rv2 rename dtb. by @sven-ola in armbian/build#9531
- SpacemiT: Add SD card support, CPU freq scaling and other fixups. by @pyavitz in armbian/build#9518
- SpacemiT: Disable patches that made it upstream (7.0-rc4). by @pyavitz in armbian/build#9540
- spacemit: enable powervr drm driver for current 6.18 kernels. by @sven-ola in armbian/build#9515
- sunxi: bump
edgeto 6.19.y,currentto 6.18.y andlegacyto 6.12.y. by @EvilOlaf in armbian/build#9381 - Youyeetoo YY3588: Enable ES8388 audio support + RK3588 I2S MCLK gate fix . by @SuperKali in armbian/build#9534
