This week's work centers on a consolidated uwe5622 Wi-Fi/Bluetooth driver, CI and repository infrastructure changes, and board and toolchain enablement across multiple SoC families.
The uwe5622 driver has been relocated to a dedicated repository and unified across kernel versions. Initial commits address a use-after-free in mtty_probe(), resolve 157 -Wmissing-prototypes warnings, correct dev_addr const guards for kernels 5.17–6.18 under clang, and fix sdio_pub_int_init for the newer gpiod int_ap API on GCC 14. The build system now sources the driver from this repository, adds a GitHub Actions test workflow, and refactors the associated DVFS patch and kernel configuration.
CI and publishing pipelines received substantial attention. Nightly images have moved from the os to the ci release channel, with the download portal, router, and reporting scripts updated to match. The community build now publishes to its own repository and version series, dispatch inputs have been trimmed, and board/maintainer dropdowns are auto-generated for standard-support builds. Stall recovery gained a five-attempt budget with a >50% success gate, later raised back to ten attempts. On the repository side, repo-reprepro now skips missing .deb files rather than aborting and logs a single count of skipped packages.
Platform work spans several architectures. New boards include the Anbernic RG Vita Pro (RK3576) handheld and the Recomputer RK3576 devkit, while EasePi-A2/R2 mainline U-Boot advances to v2026.07. Toolchain fixes enable imx8ulp libbpf builds on GCC 15, fit the AM62P/AM62-LP R5 SPL into SRAM under GCC 13, and correct a sunxi-6.12 Bluetooth quirk for the pre-6.16 API. Additional user-visible changes include a new BTRFS_CHECKSUM build switch, F2FS enabled across all kernels via a central config hook, and parallelized patch rewriting scaled to nproc.
#Armbian #EmbeddedLinux #RK3576 #uwe5622 #CI
