JetHub D1+, A clean alternative to DIY SBC builds for automation
Forget messy DIY wiring. JetHub D1+ delivers production-ready automation with integrated Zigbee, RS-485, and isolated I/O in a compact DIN-rail package running Armbian or Home Assistant OS.
Building a serious automation system shouldn’t mean spending days wiring SBCs, shields, USB dongles, level shifters and external power protection. JetHub D1+ offers a clean alternative: a compact, integrated, production-ready controller built for smart buildings, industrial automation, energy management, BMS, dispatching, and reliable IoT deployments.
This device is developed and manufactured by JetHome and comes ready for the field: no breadboards, no compatibility guessing, no driver hunting. Every interface is engineered, tested, and electrically protected. Software support includes Armbian Linux or Home Assistant OS out of the box.
Why JetHub D1+ instead of SBC + modules?
Unlike assembled DIY stacks, JetHub D1+ provides:
  1. Integrated and tested hardware – Zigbee, RS-485, isolated I/O and relays work out of the box
  2. 2. Electrical resilience – galvanic isolation, EMI-safe design, stable power delivery
  3. DIN-rail housing – ready for electrical panels and server cabinets
  4. Industrial interfaces – RS-485 (Modbus), relay outputs, digital I/O
  5. Reliable software base – Armbian support and update infrastructure
  6. Silent 24/7 operation – fanless and stable in long-term deployments
This is hardware you can deploy both at home and in production environments without improvisation.
Hardware overview
Powered by the Amlogic A113X quad-core Cortex-A53 SoC, JetHub D1+ delivers efficient performance with a stable thermal profile suitable for enclosure-based installations.
Specification
Details
CPU
Amlogic A113X, quad-core Cortex-A53
RAM
2 GB DDR4
Storage
32 GB eMMC
Wireless
Dual-band Wi-Fi + Bluetooth 5.0 (RTL8822CS)
Zigbee
Zigbee 3.0 module (EFR32MG21)
Ethernet
10/100 Mbit/s
USB
USB 2.0
Mounting
DIN-rail
Cooling
Fanless
Power
9–56 V DC
Automation interfaces for real projects
JetHub D1+ includes interfaces needed in the real world ready for direct field connection without adapters:
Interface
Purpose
4 × Digital Inputs (isolated)
Sensors, buttons, automation signals
3 × Relay Outputs (5 A / 250 V)
Lighting, contactors, low-power loads
2 × isolated RS-485 buses
Modbus RTU, PLCs, industrial devices
1-Wire (DS2482)
Temperature sensors
Internal temperature sensor
CPU thermal control
Software: Armbian or home Assistant – Your Choice
JetHub D1+ ships with a preinstalled OS of your choice:
Armbian
  • Full Linux environment
  • SSH access, Debian ecosystem
  • Ideal for automation gateways, custom services
  • Docker, MQTT, Node-RED, Python support
Home assistant OS
  • Ready-to-use smart home controller
  • Built-in Zigbee2MQTT compatibility
  • Add-ons ecosystem
  • Perfect for automation integrators
Both are officially supported images from JetHome with regular updates available.
Connectivity for modern automation
JetHub D1+ provides native Zigbee (no USB dongles required) and can seamlessly combine both wireless and wired field devices in a single automation network:
  • Pair Zigbee sensors and switches natively
  • Integrate RS-485 meters, relays and PLCs
  • Combine Zigbee2MQTT + Modbus + MQTT in one system
  • Remote control via VPN or SSH
  • MQTT ready gateway function
Documentation and support
Full documentation is available, including schematics, API interfaces and wiring examples:
Technical docs: JetHub D1+ Full Specifications
Support community: https://t.me/jethome_iot
Availability
The JetHub D1+ is now available for worldwide shipping through JetHome’s official AliExpress store.
Order JetHub D1+ on AliExpress
https://jethome.aliexpress.com
JetHub D1+ is a reliable controller for automation deployments where stability matters more than cable experiments. With Armbian support, tested hardware integration and industrial I/O, it bridges the gap between DIY flexibility and professional-grade engineering.
Whether you’re building: Smart home hubs, Industrial monitoring, Energy management systems, IoT gateways, BMS / HVAC automation, Remote telemetry controllers, JetHub D1+ is a strong foundation to build on.
