This cycle is defined by the launch of the armbian/external packaging pipeline, broad kernel and U-Boot version bumps across platforms, and substantial desktop and repository infrastructure work.
The new armbian/external repository establishes a dedicated build and mirror pipeline for third-party software, with tooling for dependency checks, parallel sync, incremental uploads, and a package site published at external.armbian.com. Initial payloads include charsiu for the RK3576 NPU, developer tools such as claude-code, codex, grok-cli, Zed, and a GitHub CLI build for riscv64, alongside a full Armbian Hyprland shell derived from the Omarchy port with companion packages for snapper snapshots, encrypted-root first boot, and Hyprland 0.57.0 titlebars. A new update-manager for Armbian has also been built and promoted to stable.
Kernel and bootloader work advanced across the lineup: edge kernels moved to 7.3.1 for qcs6490, qrb2210, sc8280xp, and mvebu, while the imx8m family moved to 7.3 and rockchip64 bleedingedge advanced to 7.4-rc1. Mainline U-Boot v2026.10 landed on Orange Pi 5, NanoPi M5, Mekotronics R58-4x4, Banana Pi M2, and Youyeetoo YY3588/R1. Platform fixes include RK3588 vendor-next CPU frequency scaling, RK356x HDMI fractional PLL and HDMI 2.0 scrambling for 4K@60, Rockchip64 runtime PM backports for 6.18, SpacemiT K1 fixes for the JPU driver and U-Boot vprintf overflow, and new board support for Torder R10D, Orange Pi A31s, DEBIX Model A, and Orange Pi 5 Ultra WiFi. Security coverage expanded with per-run kernel CVE patch selection in CI and Claude-assisted backports for 6.1 and 6.12.
On the desktop and repository side, Hyprland was added as a supported desktop with tiered package lists and a dedicated forky/sid x86 image, KDE Plasma gained persistent branding and Discover integration, and GNOME received Numix icons, a Ptyxis-based dock, and an Armbian wallpaper on the GDM login screen. The repository update workflow was rebuilt to separate incoming, beta, and stable flows, publish from configuration files, coordinate copies with live CI uploads, and consume external packages from the new pipeline. Imager received Windows flash fixes and AppImage repacking cleanup, and armbian-install gained btrfs @ subvolume creation, SPI image selection by install target, and UFS rootfs handling.
#armbian #embeddedlinux #rockchip #uboot #hyprland
