This cycle advances three fronts: kernel branch progression and SoC maintenance, expanded board coverage, and improvements to the first-boot and desktop user experience.
On the kernel side, several platforms migrated their edge branch from 7.2 to 7.3 with rewritten configurations, including k3, mvebu64, s5p6818, sprd-ums512, odroidxu4, and cix-p1, while rockchip64-7.4 was rebased against 7.4-rc3 with a large rk3576-rocket rework and mainline-kernel bumped to v7.4-rc4. Sunxi received substantial attention with H616 PSCI suspend support, display-engine IOMMU integration, lima GPU fault recovery, HDMI audio fixes, and a Cubie A5E NVMe boot fix, alongside multiple CVE backport rounds for 6.1, 6.12 and 6.18. The uwe5622 wireless driver received a coordinated series of stability fixes covering command handling, CP2 reset recovery, and TX credit accounting.
Board coverage expanded with the JetHome JetHub D3, ArmSoM Sige7s, Bobcat 29X, LCKFB Taishan Pi 3M, Orange Pi Zero 4, and OnePlus 10 Pro, and bananapipro was promoted to standard support. Platform-specific enablement included onboard Wi-Fi for the Orange Pi 5 Ultra on both current and edge, a RK3566 2 GHz OPP overlay, and expanded RK3562 peripheral support. Firmware updates covered AP6356S NVRAM porting and an aic8800D80 refresh addressing 2.4 GHz AP mode.
User-facing changes focused on first-boot polish and desktop defaults, including Plymouth splash screens on desktop images, HiDPI scaling in armbian-firstlogin, an on-screen keyboard in armbian-firstrun-gui, geolocation fallback to manual selection, and locale persistence across reboots. The armbian-kernel configuration gained dm-crypt in all kernels, CephFS and RBD modules, and RAM-sized zram swap, while bcm2711 images received Adiantum root encryption and quiet boot. The armbian-hyprland-shell received several refinements covering lock-screen behavior, locale-driven language, and Num Lock defaults.
#Armbian #EmbeddedLinux #Rockchip #Sunxi #KernelDevelopment
- cix-p1: fix loadavg >=1 while being idle and rewrite patches. by @EvilOlaf in armbian/build#11417
- JetHome: add JetHome JetHub D3 (j310) support. by @QwaSeeK in armbian/build#10948
- add ArmSoM Sige7s edge support. by @amazingfate in armbian/build#11326
- Add Bobcat 29X (RK3566) as community supported board. by @nmaiorsky in armbian/build#11177
- Added Orange Pi Zero 4. by @JoshCodeStuff in armbian/armbian.github.io#573
- announce-merge workflow: show PR title instead of most recent commit msg. by @EvilOlaf in armbian/build#11509
- arm64: dts: rockchip: add imx219 link-frequencies across the tree. by @Mkiring in armbian/linux-rockchip#623
- arm64: dts: rockchip: lckfb-tspi-3m: run the fan at full speed. by @gahingwoo in armbian/linux-rockchip#618
- armbian-apt-updates: count security upgrades on Debian too. by @SkillDMonkey in armbian/build#11423
- armbian-firstlogin: fall back to manual choice when geolocation fails. by @igorpecovnik in armbian/build#11487
- armbian-firstlogin: fix the Xfce HiDPI scale. by @igorpecovnik in armbian/build#11401
- armbian-firstlogin: query ipwhois.app over HTTPS. by @SkillDMonkey in armbian/build#11433
- armbian-firstlogin: use the 2x xfwm4 theme on HiDPI. by @igorpecovnik in armbian/build#11404
- armbian-firstlogin: write the locale that survives a reboot. by @igorpecovnik in armbian/build#11426
- armbian-firstrun-gui: 0.1.6, more location services. by @igorpecovnik in armbian/external#106
- armbian-firstrun-gui: add an on-screen keyboard. by @retro98boy in armbian/external#105
- armbian-hyprland-shell: containerd starts with Docker, not at boot. by @igorpecovnik in armbian/external#102
- armbian-hyprland-shell: keep the lock screen lit after a DPMS wake. by @igorpecovnik in armbian/external#87
- armbian-hyprland-shell: no Hyprland update notice for new users. by @igorpecovnik in armbian/external#101
- armbian-hyprland-shell: shell language from the system locale. by @igorpecovnik in armbian/external#95
- armbian-hyprland-shell: start with Num Lock off. by @igorpecovnik in armbian/external#89
- armbian-images: keep empty fields when loading reusable.yml. by @igorpecovnik in armbian/armbian.github.io#571
- armbian-install: accept vanished files, align free-space partition. by @igorpecovnik in armbian/configng#1139
- armbian-install: detect UFS and finish the ufs install mode. by @SuperKali in armbian/configng#1144
- armbian-kernel: allow loading modules with a mismatched split BTF. by @asovetov in armbian/build#11479
- armbian-kernel: enable Ceph clients (CephFS, RBD) as modules. by @igorpecovnik in armbian/build#11437
- armbian-kernel: enable dm-crypt in all kernels. by @igorpecovnik in armbian/build#11453
- armbian-kernel: real-time group scheduling off by default. by @igorpecovnik in armbian/build#11419
- armbian-snapshots: 1.0.4, faster GRUB snapshot entries. by @igorpecovnik in armbian/external#100
- armbian-snapshots: 1.0.5, config visible to snapperd at first boot. by @igorpecovnik in armbian/external#104
- armbian-zram-config: size zram swap by RAM. by @igorpecovnik in armbian/build#11456
- atf: sunxi64: H616 PSCI CPU_SUSPEND and SYSTEM_SUSPEND without SCP; sunxi-7.3: cpu-sleep idle state. by @SomeComputerGuy in armbian/build#11317
- Automate organisation profile live data. by @igorpecovnik in armbian/armbian.github.io#567
- bananapipro: add maintainer, move to standard support. by @cyryllo in armbian/build#11445
- bcm2711: disable CONFIG_MISC_RP1 (Pi 5 hangs at boot since 6.18.62). by @naltatis in armbian/build#11510
- bcm2711: encrypt the root with Adiantum. by @igorpecovnik in armbian/build#11421
- bcm2711: quiet boot with Plymouth splash. by @igorpecovnik in armbian/build#11416
- bcm2711: set CONFIG_RCU_EXP_CPU_STALL_TIMEOUT to 0. by @igorpecovnik in armbian/build#11413
- bcm2711: show the Plymouth splash on desktop images. by @igorpecovnik in armbian/build#11418
- bcmdhd: fix error codes lost to misplaced parentheses. by @m-bruck in armbian/bcmdhd-dkms#19
- board-images: add OnePlus 10 Pro (oneplus-negroni). by @kwaa in armbian/armbian.github.io#574
- board: bump u-boot for 9tripod-x3568-v4 and graperain-g3568-v2. by @rbqvq in armbian/build#11192
- brcm: port AP6356S NVRAM and board-specific files from linux-firmware. by @rbqvq in armbian/firmware#156
- bsp: Armbian colors in whiptail, debconf and dialog. by @igorpecovnik in armbian/build#11349
- bsp: armbian-ramlog - keep log subdirectories when USE_RSYNC=false. by @SkillDMonkey in armbian/build#11470
- bsp: honor loglevel= from the kernel command line. by @igorpecovnik in armbian/build#11410
- chore(deps): resolve Dependabot alerts published since 2026-10-29. by @SuperKali in armbian/website#69
- chore: point the homepage at armbian.com/imager. by @SuperKali in armbian/imager#253
- ci: labels: apply the later review fixes from armbian/build. by @igorpecovnik in armbian/external#86
- ci: labels: follow the review state and count every changed line. by @igorpecovnik in armbian/build#11399
- ci: re-run jobs GitHub never assigned to a hosted runner. by @SuperKali in armbian/imager#252
- cix-p1: move edge to 7.3. by @igorpecovnik in armbian/build#11384
- config: add git_sources.json with pinned source SHA1s for v26.11. by @igorpecovnik in armbian/build#11447
- cve: backports for 2 CVEs on 6.18 and 6.12. by @igorpecovnik in armbian/cve#264
- cve: Claude backports for 3 CVEs on 6.12 and 6.1. by @igorpecovnik in armbian/cve#260
- cve: Claude backports for 4 CVEs on 6.18 and 6.12. by @igorpecovnik in armbian/cve#262
- cve: Claude backports for 5 CVEs on 6.1. by @igorpecovnik in armbian/cve#266
- debian: prepare bcmdhd 101.10.591.52.27-11. by @KingFalse in armbian/bcmdhd-dkms#18
- depcheck: check earlier failures again, close the issue when all pass; firefox: leave out geckodriver. by @igorpecovnik in armbian/external#99
- depends-on: Notify-when for the kernels Armbian builds. by @iav in armbian/actions#49
- desktops: do not wait for intel_lpmd at boot. by @igorpecovnik in armbian/configng#1146
- desktops: psd only for real users; longer stop cap with Hyprland. by @igorpecovnik in armbian/configng#1143
- desktops: set HiDPI scale on desktop install. by @igorpecovnik in armbian/configng#1140
- desktops: xfce: move and resize windows with their content. by @igorpecovnik in armbian/configng#1141
- docs(build): document testing an image with QEMU. by @swastiktawate in armbian/documentation#1767
- Document bootscript templating. by @swastiktawate in armbian/documentation#1766
- dtoverlays: support grub-with-dtb boards. by @SuperKali in armbian/configng#1147
- Enable Bianbu desktop for SpacemiT K1 boards. by @igorpecovnik in armbian/armbian.github.io#572
- extensions/fake-hwclock-load-fix: apply the 0.14 load fix on every image. by @defcom5-rockchip in armbian/build#11480
- extensions/fake-hwclock-load-fix: use Ubuntu's own package on Ubuntu. by @defcom5-rockchip in armbian/build#11490
- extensions: meson-bl301: build ODROID-HC4 BL301 from source. by @iav in armbian/build#11402
- Fix broken links in board maintainer documentation. by @swastiktawate in armbian/documentation#1768
- fix(ci): skip the auto-retry for PRs that are no longer open. by @SuperKali in armbian/imager#254
- fix(ui): make log upload behave the same on every surface. by @SuperKali in armbian/imager#251
- fix: register packaged QEMU formats during Docker cross-builds. by @mvanhorn in armbian/build#11489
- fs-cryptroot-support: minimal PBKDF2 cost for the autounlock key file. by @igorpecovnik in armbian/build#11420
- genio: edge: enable IR receivers (mceusb) and LIRC. by @rpardini in armbian/build#11484
- genio: edge: MDP3 GCE runtime PM, vcodec capture-queue guard, vb2 cache sync. by @rpardini in armbian/build#11363
- Genio: update mtk-flash and mtkbin references. by @rbrok in armbian/build#11492
- getting-started: update armbian-install page for the new installer. by @igorpecovnik in armbian/documentation#1782
- Hide cix-acpi, list the Cix P1 boards on its image. by @igorpecovnik in armbian/armbian.github.io#528
- image-output-iso: use grub serial only when com0 exists. by @igorpecovnik in armbian/build#11400
- k3: edge: bump to 7.3 and rewrite kernel configs. by @igorpecovnik in armbian/build#11451
- lckfb-taishanpi-3m: add LCKFB Taishan Pi 3M (RK3576). by @gahingwoo in armbian/build#11324
- lckfb-taishanpi: set BOARD_VENDOR to lckfb and rename to Taishan Pi 1M. by @sckiyo in armbian/build#11488
- lenovo-y700-gen4: split GRUB images without loop devices. by @retro98boy in armbian/build#11371
- mainline-kernel: bump v7.4 to v7.4-rc4; large rk3576-rocket rebase. by @rpardini in armbian/build#11496
- mesa-libclc: build from source for trixie, forky and resolute. by @igorpecovnik in armbian/external#96
- mesa: use mesa-libclc on every release. by @igorpecovnik in armbian/external#97
- Meson64 kernel fixes. by @EvilOlaf in armbian/build#11508
- meson64: restore the GPIO interrupt routing after hibernation. by @iav in armbian/build#11446
- mvebu64: edge: bump to 7.3 and rewrite kernel config. by @igorpecovnik in armbian/build#11448
- nvidia: mask nvidia-settings autostart without an NVIDIA GPU. by @igorpecovnik in armbian/build#11403
- odroidhc4: u-boot: tell BL301 whether to wake on LAN. by @iav in armbian/build#11405
- odroidxu4: bump edge kernel 7.2 -> 7.3. by @igorpecovnik in armbian/build#11502
- Orange Pi Zero 4: Add community support for Orange Pi Zero 4 (Allwinner A733). by @JoshCodeStuff in armbian/build#11469
- orangepi5-ultra: enable onboard Wi-Fi on current 6.18. by @KingFalse in armbian/build#11370
- orangepi5-ultra: enable onboard Wi-Fi on edge. by @KingFalse in armbian/build#11440
- partitioning: separate /boot defaults to 1024 MiB. by @igorpecovnik in armbian/build#11452
- patching: keep the description when b4 omits the "---" separator. by @rpardini in armbian/build#11385
- profile-sync-daemon: skip Chromium and Chrome when not installed. by @igorpecovnik in armbian/external#90
- profile: add auto-refreshed live blocks. by @igorpecovnik in armbian/.github#4
- radxa-dragon-q6a, q8b: device tree overlays on GRUB boards. by @SuperKali in armbian/build#11443
- release-targets: use cix-acpi images for CIX P1 boards. by @igorpecovnik in armbian/armbian.github.io#575
- release-targets: virtual boards take all branches. by @igorpecovnik in armbian/armbian.github.io#570
- Rockchip64 kernel fixes. by @EvilOlaf in armbian/build#11507
- rockchip64-6.18: backport per-device ops for rockchip-iommu. by @asovetov in armbian/build#11491
- rockchip64-6.18: backport VDPU381 VP9 decoding. by @KingFalse in armbian/build#11459
- rockchip64-6.18: drop the can_put_echo_skb() patch, upstream in 6.18.64. by @igorpecovnik in armbian/build#11415
- rockchip64-7.3: drop upstreamed CAN patches. by @igorpecovnik in armbian/build#11412
- rockchip64-7.4: khadas-edge2: restore MCU fan control. by @rpardini in armbian/build#11474
- rockchip64-7.4: many of sre's USBDP/fusb/inno/drm series. by @rpardini in armbian/build#11472
- rockchip64-7.4: mekotronics-r58x-pro: DT rework for upstream submission. by @rpardini in armbian/build#11473
- rockchip64-7.4: rewrite patches (correctly). by @rpardini in armbian/build#11483
- rockchip64-7.4: rewrite patches against 7.4-rc3. by @rpardini in armbian/build#11471
- rockchip64: add RK3566 2 GHz CPU OPP overlay. by @lukaszsobala in armbian/build#11442
- rockchip64: carry over what landed on v7.3 to v7.4. by @rpardini in armbian/build#11460
- rockchip64: enable more RK3562 peripherals and update KICKPI K3B support. by @retro98boy in armbian/build#11180
- rockchip64: fail write_uboot_platform_ufs when a write fails. by @SuperKali in armbian/build#11427
- rockchip64: fix rk3562-0032-media-rga-add-RK3562-RGA2e-support.patch. by @retro98boy in armbian/build#11428
- rootfs: wait for CR before gadget serial autologin output. by @mingzhangqun in armbian/build#11183
- rpi-eeprom: add the missing dependencies. by @igorpecovnik in armbian/external#92
- rpi-eeprom: newer bootloader images. by @igorpecovnik in armbian/external#91
- runner-cleanup: cap git_cdn and kernel worktree caches. by @igorpecovnik in armbian/configng#1142
- runner-cleanup: keep the Armbian git trees in the _work wipe. by @igorpecovnik in armbian/configng#1145
- runner-cleanup: start stopped service containers, do not prune them. by @igorpecovnik in armbian/configng#1149
- s5p6818: edge: bump to 7.3 and rewrite kernel config. by @igorpecovnik in armbian/build#11449
- sc8280xp-edge (v7.3): backport reworked iris Gen2 firmware autodetect for v7.3.6. by @rpardini in armbian/build#11513
- Show the Plymouth boot logo on desktop images by default. by @igorpecovnik in armbian/build#11455
- SpacemiT K1: PCI: do not advertise ASPM L1 (NVMe drops off the bus). by @frederic-mahe in armbian/build#11411
- sprd-ums512: edge: bump to 7.3 and rewrite kernel config. by @igorpecovnik in armbian/build#11450
- sun50iw9: TF-A: H616: power cores on through the CPUIDLE block. by @SomeComputerGuy in armbian/build#11454
- sun55iw3: clean up board configs, pin TF-A, take upstream THS and SPI NOR patches. by @SuperKali in armbian/build#11461
- sunxi-6.18, sunxi-7.3: cubietruck: run the RTC from the 32k crystal. by @DRracer in armbian/build#11465
- sunxi-6.18, sunxi-7.3: h616: PWM3/PWM4 overlays on PH0/PH1 release UART0. by @SomeComputerGuy in armbian/build#11313
- sunxi-6.18, sunxi-7.3: hdmi audio: fix A10 reset values and a DMA channel leak (folded into the HDMI audio patch). by @DRracer in armbian/build#11407
- sunxi-6.18, sunxi-7.3: iommu: sun55i: drop the stale struct iommu_dma_cookie copy. by @SomeComputerGuy in armbian/build#11378
- sunxi-6.18, sunxi-7.3: lima: recover from GPU page faults instead of hanging. by @DRracer in armbian/build#11464
- sunxi-6.18, sunxi-7.3: mbus: add the A10/A20 Mali GPU (black screen on 2 GiB Cubietruck). by @DRracer in armbian/build#11372
- sunxi-6.18, sunxi-7.3: mbus: restore the DMA offset when a driver binds again. by @DRracer in armbian/build#11373
- sunxi-6.18: drop upstream patches and rewrite, fixing build breakage. by @EvilOlaf in armbian/build#11506
- sunxi-6.18: sun4i-gpadc: backport megous' busy-wait fix from sunxi-7.3 (10 % CPU on idle A10). by @DRracer in armbian/build#11409
- sunxi-7.3: 7.3.6 fixes. by @EvilOlaf in armbian/build#11504
- sunxi-7.3: ASoC sunxi_v2: let the AHUB DAM card probe; enable it on the Orange Pi Zero2. by @SomeComputerGuy in armbian/build#11352
- sunxi-7.3: backport two Linux 7.4 PM fixes (s2idle without suspend_ops->begin, DPM watchdog phases). by @SomeComputerGuy in armbian/build#11310
- sunxi-7.3: h616: put the display engine behind the IOMMU. by @SomeComputerGuy in armbian/build#11390
- sunxi-7.3: orangepi-zero2: rgmii-rxid, mmc aliases, SPI NOR supply, USB-C host overlay. by @SomeComputerGuy in armbian/build#11312
- sunxi-7.3: spi-sun6i: H616 dual read; Orange Pi Zero2 SPI NOR over two lines. by @SomeComputerGuy in armbian/build#11422
- sunxi/rockchip64: rewrite patches. by @EvilOlaf in armbian/build#11444
- sunxi64: restore CONFIG_TCP_CONG_BBR on current & edge. by @LeisureLinux in armbian/build#11424
- sunxi: fix build warnings in Armbian-carried kernel patches (sunxi-6.18, sunxi-7.3, dtc). by @SomeComputerGuy in armbian/build#11377
- sunxi: fix Cubie A5E NVMe boot hang and clean up boot warnings. by @SuperKali in armbian/build#11458
- targets-compositor: add exclude rules to drop single images. by @igorpecovnik in armbian/build#11462
- tinker-edge-r: add the DTS to current, edge and bleedingedge. by @ARC-MX in armbian/build#11213
- u-boot: sunxi64: orangepizero2: AXP305 over RSB in the SPL, SPI NOR install. by @SomeComputerGuy in armbian/build#11316
- u-boot: v2027.01: rebase pxe-over-http-v0 on rc2. by @igorpecovnik in armbian/build#11430
- uefi: set CONFIG_RCU_EXP_CPU_STALL_TIMEOUT to 0. by @igorpecovnik in armbian/build#11414
- uefi: smaller initramfs, MODULES=dep after the first boot. by @igorpecovnik in armbian/build#11432
- unit-tests: never remove host containers by name. by @igorpecovnik in armbian/configng#1148
- Up aic8800D80 SDIO firmware to Dec 2025 build (fixes 2.4 GHz AP mode). by @fuleo in armbian/firmware#137
- Update ArmSoM vendor logo to official color wordmark. by @as-jackson in armbian/armbian.github.io#568
- uwe5622: 64-bit station byte counters, quieter CP sleep/wakeup logging. by @lukaszsobala in armbian/uwe5622#39
- uwe5622: service fixes, power save off, Bluetooth via btattach, driver update. by @igorpecovnik in armbian/build#11345
- wireless: uwe5622: do not cancel the loopcheck work from itself. by @SomeComputerGuy in armbian/uwe5622#35
- wireless: uwe5622: do not read a sent command on timeout. by @SomeComputerGuy in armbian/uwe5622#33
- wireless: uwe5622: do not read the station index of a command. by @SomeComputerGuy in armbian/uwe5622#32
- wireless: uwe5622: release the card when a direct access is refused. by @SomeComputerGuy in armbian/uwe5622#38
- wireless: uwe5622: restart WLAN and Bluetooth after a CP2 reset. by @SomeComputerGuy in armbian/uwe5622#37
- wireless: uwe5622: tty-sdio: return the TX credit when a push fails. by @SomeComputerGuy in armbian/uwe5622#36
- wireless: uwe5622: unlink an interface before freeing it. by @SomeComputerGuy in armbian/uwe5622#34
