Armbian Newsletter September 2026
JetHome boosts Armbian CI
JetHome (Shenzhen JetHome Technology Co.) donated a build server for Armbian. The server compiles Armbian images, kernels and U-Boot packages. Thank you, JetHome. HW Specifications CPU 2 × Intel Xeon Gold 6148, 80 threads Memory 384 GB Storage 3.84 TB SSD, plus 20 TB of disk Network 2 × 1
Sponsored
This week’s work centers on Rockchip platform maturation, kernel and toolchain modernization, and board-level enablement across vendors. Rockchip received the largest share of attention, with RK3528 gaining a thermal driver, cooling-map refinements, and cleanup of legacy PCIe and pmdomain workarounds. The Radxa E24C now stores its U-
Booting every board, every night
Armbian builds for hundreds of boards. A kernel bump that is clean on one SoC can leave another unbootable and no build log will tell you. So there is a rack, and the rack boots them. Compiling is not evidence. A kernel that builds, packages that install, an image that
Mali GPU with LiteRT-LM
Running Gemma 4 E2B on a Mali GPU with LiteRT-LM This guide should work on any armbian minimal/console (trixie) system with a working Mali-g610 GPU. DO NOT USE DESKTOP Verified on: Orange Pi 5 Max (Rockchip RK3588, Arm Mali-G610 MC4), Armbian/Debian 13 (trixie), aarch64, 8
