SBC storage
SBC storage
Modernizing SBC Storage: From Qualcomm EDL Flashing to SPI-to-NVMe Boots
For years, single-board computer (SBC) storage followed a simple, predictable pattern: flash an image onto a microSD card or eMMC module, plug it in, and turn on the board. However, as modern embedded hardware approaches laptop-grade performance, that legacy approach is starting to break down.
The latest quarter of Armbian development highlights a major shift toward modern storage pipelines. By combining Qualcomm Emergency Download (EDL) flashing in Armbian Imager 2.0 with a redesigned installation engine, Armbian is making high-performance hardware far easier to set up.
Direct Qualcomm flashing with Imager 2.0
As boards like the Radxa Dragon Q6A and Q8B bring Qualcomm Snapdragon chips to developers, standard image writers no longer work. These devices require low-level vendor tools to write to storage before an operating system can even start.
Armbian Imager 2.0 now handles EDL flashing directly over USB without third-party software, automatically tailoring the setup to the specific hardware:
Radxa Dragon (Q6A & Q8B): Flashes directly to high-speed UFS storage, setting up the board’s custom UEFI boot environment.(Note: Users will need to enter the UEFI menu and set the boot order manually after flashing to boot from UFS).
Arduino Qualcomm Boards: Flashes directly to onboard eMMC storage, setting up a U-Boot environment.
Because EDL writes straight to the main storage, it leaves external SPI flash completely untouched, providing a clean, single-step recovery or setup process.
Decoupling boot files for faster drives
On powerful boards like those using the Rockchip RK3588, running an entire system from an SD card or eMMC creates a storage bottleneck. The ideal setup separates where the board starts from where it runs: loading basic boot files from tiny onboard memory (SPI NOR flash), then handing the heavy lifting off to a fast NVMe SSD or SATA drive.
